QoS Priority Mapping Configuration
To configure QoS priority mapping:
  1. Select the Priority Mapping tab.
    Network - Quality of Service (QoS) Screen
  2. Set the following parameters for IP DSCP mappings for untagged frames:
    DSCP
    Lists the DSCP value as a 6-bit parameter in the header of every IP packet used for packet classification.
    802.1p Priority
    Assign a 802.1p priority as a 3-bit IP precedence value in the Type of Service field of the IP header used to set the priority. The valid values for this field are 0-7. Up to 64 entries are permitted. The priority values are:
    0 – Best Effort
    1 – Background
    2 – Spare
    3 – Excellent Effort
    4 – Controlled Load
    5 – Video
    6 – Voice
    7 – Network Control
    Use the spinner controls within the 802.1p Priority field for each DSCP row to change its priority value.
  3. Set or override the following parameters for IPv6 Traffic Class Mapping for untagged frames:
    Traffic Class
    Devices that originate a packet must identify different classes or priorities for IPv6 packets. Devices use the traffic class field in the IPv6 header to set this priority.
    802.1p Priority
    Assign a 802.1p priority as a 3-bit IPv6 precedence value in the Type of Service field of the IPv6 header used to set the priority. The valid values for this field are 0-7. Up to 64 entries are permitted. The priority values are:
    0 – Best Effort
    1 – Background
    2 – Spare
    4 – Controlled Load
    5 – Video
    6 – Voice
    7 – Network Control
  4. Select the OK button located at the bottom right of the screen to save the changes.
    Select Reset to revert to the last saved configuration.
