Enable Signature |
Clear the checkbox to deactivate the WIPS signature for
use with the profile. The signature is activated by
default |
BSSID MAC |
Select BSSID MAC to define a BSS
ID MAC address used for matching and filtering with the
signature |
Source MAC |
Define a source MAC address for packets examined for
matching, filtering, and potential device exclusion using
the signature |
Destination MAC |
Set a destination MAC address for the packet examined for
matching, filtering, and potential device exclusion with the
signature |
Matching Frame |
Use the drop-down list box to select a frame type for
matching and filtering with the WIPS signature |
Matching SSID |
Set the SSID used for matching and filtering with the
signature. Ensure that it is specified properly, or the SSID
will not be properly filtered |
SSID Length |
Set the character length of the SSID used for matching
and filtering with this signature. The maximum length is 32
characters |
Wireless Client Threshold |
Specify the threshold limit per client that, when
exceeded, signals the event. The configurable range is from
1 to 65,535 |
Radio Threshold |
Specify the threshold limit per radio that, when
1 to 65,535 |
Filter Expiration Time |
Set a Filter Expiration from 1 through 86,400 seconds
that specifies the duration a client is excluded from RF
Domain manager radio association when responsible for
triggering a WIPS event |
