Change the Admin Status of an Interface
You can bring an interface administratively up or down.
Tip
Tip
In SLX-OS, you can use the show interface ethernet command to see the status of the Ethernet interfaces on your device.
You can change the Admin Status for one or more IP addresses or for a specified fabric. For more configuration examples, see the Extreme Fabric Automation Command Reference.
The efa inventory device interface set-admin-state command is an operational (or exec) command, not a configuration command. With operational commands, there is no configuration persistence, no drift identification, and no configuration reconciliation. You run operational commands as needed.
Run the efa inventory device interface set-admin-state command.
This example changes the Admin State on multiple IP addresses.
--ip 10.25.225.167,10.24.48.131,10.24.51.135 --if-name 0/20-22 --state up
|   DeviceIP    | ID  | Name | Interface Type | Admin Status | Result  | Reason |
| 10.24.48.131  | 110 | 0/21 | ethernet       | up           | Success |        |
|               | 142 | 0/20 | ethernet       | up           | Success |        |
|               | 148 | 0/22 | ethernet       | up           | Success |        |
| 10.24.51.135  | 16  | 0/21 | ethernet       | up           | Success |        |
|               | 86  | 0/20 | ethernet       | up           | Success |        |
| 10.25.225.167 | 9   | 0/21 | ethernet       | up           | Success |        |
|               | 89  | 0/20 | ethernet       | up           | Success |        |
|               | 1   | 0/22 | ethernet       | up           | Success |        |
Interface Details
--- Time Elapsed: 56.4964544s ---
This example changes the Admin Status for the specified fabric.
efa inventory device interface set-admin-state --fabric nc_no_vni
| 10.24.51.135 | 48  | 0/22 | ethernet       | up           | Success |        |
| 10.24.48.131 | 148 | 0/22 | ethernet       | up           | Success |        |
Interface Details
--- Time Elapsed: 37.9236481s ---
