You can back up and restore the EFA system, including the database and certificates.
efa system backup Backup file :: /apps/efa_logs/backup//EFA-2020.08.21-00.15.02.tar --- Time Elapsed: 9.603815206s ---
efa system restore --backup-tar EFA-2020.08.21-00.15.02.tar Backup file name: EFA-2020.08.21-00.15.02.tar Restore result :: Restore operation is successful --- Time Elapsed: 3m11.269648985s ---
Tip
You can use the efa system backup-list command to see a list of available backup tar files.
