Exclusion of VLAN/BD from Cluster Instance
EFA excludes the VLANs/BDs used in l3-hand-off (towards external-gateway) EPG from cluster instance by configuring member vlan remove <vlan-range> and member bridge-domain remove <bd-range> under the cluster instance.
During EFA upgrade, EFA marks all the VLANs/BDs used in l3-hand-off EPGs with the intended member vlan remove <vlan-range> and member bridge-domain remove <bd-range> configuration and shows as configuration drift. On reconciliation of the drift, EFA pushes member vlan remove <vlan-range> and member bridge-domain remove <bd-range> configuration under the cluster.
EFA Provisioning
# efa tenant create --name tenant1 --port 10.24.80.134[0/1-10],10.24.80.135[0/1-10] --vlan-range 2001-2010
# efa tenant po create --name po1 --tenant tenant1 --port 10.24.80.134[0/1],10.24.80.135[0/1]--speed 10Gbps --negotiation active
# efa tenant epg create --name L3HandoffEPG1Ten1 --tenant tenant1 --ctag-range 2001-2003 --switchport-mode trunk --po po1 --type l3-hand-off
Device1 # show run interface Port-channel 1
cluster-client auto
switchport
switchport mode trunk
switchport trunk allowed vlan add 2001-2003
no switchport trunk tag native-vlan
no shutdown
Device1# show running config-evpn
evpn-fabric1
route-target both auto ignore-as
rd auto
duplicate-mac-timer 5 max-count 3
Device1# show running-config cluster
cluster fabric1-cluster-1
peer 10.20.20.5
peer-interface Port-channel 64
peer-keepalive
auto
member vlan-all
member vlan remove 2001-2003
member bridge-domain all
Device2 # show run interface Port-channel 1
cluster-client auto
switchport
no shutdown
Device2# show running config-evpn
evpn-fabric1
rd auto
Device2# show running-config cluster
peer 10.20.20.5
peer-keepalive
auto
member vlan-all
