VRF Static Route Configuration
VRF Create
# efa tenant vrf create [ --name vrf name | --tenant tenant name | --rttype <both | import | export > | --rt | --ipv4-static-route-next-hop < device ip,ipv4 static route network,nexthop ip,nexthop distance > | --ipv6-static-route-next-hop < device ip,ipv4 static route network,nexthop ip,nexthop distance > | --local-asn | --ipv4-static-route-bfd < device-ip,dest-ipv4-addr,source-ipv4-addr[interval,minrx,multiplier] > | --ipv6-static-route-bfd < device-ip,dest-ipv4-addr,source-ipv4-addr[interval,min-rx,multiplier] > | --max-path uint <1-64> | --redistribute < static | connected >| --rh-max-path uint | --rh-ecmp-enable | --help ]
VRF Update
# efa tenant vrf update [ -–name <vrf-name> --tenant <tenant-name> --operation < staticroute-add | static-route-delete> --ipv6static-route-next-hop <destination, next-hop> --ipv4static-route-next-hop <destination, next-hop> efa tenant vrf update [ --name vrf name | --tenant tenant name | --operation < local-asn-add | local-asn-delete | static-route-bfd-add | static-route-bfd-delete | static-route-add | static-route-delete | max-path-add | max-path-delete | redistribute-add | redistributedelete | rh-max-path-add | rh-max-path-delete | rh-ecmp-update > | --local-asn | --ipv4-static-route-bfd < device IP,dest-ipv4-addr,source-ipv4-addr[interval,min-rx,multiplielr] > | --ipv6-staticroute-bfd < device ip,dest-ipv6-addr,source-ipv6-addr[interval,minrx,multiplielr] > | --ipv4-static-route-next-hop < device-ip,destipv4-addr,source-ipv4-addr[interval,min-rx,multiplier] > | --ipv6-static-route-next-hop < device-ip,dest-ipv4-addr,source-ipv4-addr[interval,min-rx,multiplier] > | --max-path uint <1-64> | --redistribute < static | connected > | --rh-max-path uint | --rh-ecmpenable | --help ]
# efa tenant vrf create --name red --tenant tenant11 --ipv6-static-route-next-hop 10.24.80.134,2000::/64,1001::2 --ipv6-static-route-next-hop 10.24.80.134,2000::/64,1002::2 --ipv6-static-route-next-hop 10.24.80.134,2000::/64,1003::2 --ipv6-static-route-next-hop 10.24.80.134,2000::/64,1004::2 --ipv6-static-route-next-hop 10.24.80.135,2001::/64,1001::2,4 --ipv6-static-route-next-hop 10.24.80.135,2001::/64,1002::2 --ipv6-static-route-next-hop 10.24.80.135,2001::/64,1003::2 --ipv6-static-route-next-hop 10.24.80.135,2001::/64,1004::2 --ipv4-static-route-next-hop 10.24.80.134,22.0.0.0/24,13.0.0.1,2 --ipv4-static-route-next-hop 10.24.80.134,22.0.0.0/24,13.0.0.2 --ipv4-static-route-next-hop 10.24.80.134,22.0.0.0/24,13.0.0.3 --ipv4-static-route-next-hop 10.24.80.134,22.0.0.0/24,13.0.0.4 --ipv4-static-route-next-hop 10.24.80.135,23.0.0.0/24,13.0.0.1 --ipv4-static-route-next-hop 10.24.80.135,23.0.0.0/24,13.0.0.2 --ipv4-static-route-next-hop 10.24.80.135,23.0.0.0/24,13.0.0.3 --ipv4-static-route-next-hop 10.24.80.135,23.0.0.0/24,13.0.0.4
# efa tenant vrf show --name red --tenant tenant11
====================================================================================Name            : red
Tenant Name     : tenant11
L3 VNI          :
Route Target    :
Static Route    : Switch-IP, Network->Nh1[distance],Nh2[distance],..
                : 10.24.80.134, 22.0.0.0/24->13.0.0.1[2],13.0.0.2,13.0.0.3,13.0.0.4
                  10.24.80.135, 23.0.0.0/24->13.0.0.1,13.0.0.2,13.0.0.3,13.0.0.4
                  10.24.80.134, 2000::/64->1001::2,1002::2,1003::2,1004::2
                  10.24.80.135, 2001::/64->1001::2[4],1002::2,1003::2,1004::2
Local Asn       :
efa tenant epg create --name ten1epg1 --tenant tenant1 --port 10.24.80.134[0/11],10.24.80.135[0/11] --switchport-mode trunk –ctag-range 11 --vrf red –anycast-ip 11:10.10.11.1/24
Switch Config
Device 1# show running-config vrfred
vrf red
address-family ipv4 unicast
  route-target export 1:1 evpn
  route-target import 1:1 evpn
 ip route 22.0.0.0/24 13.0.0.1 distance 2
  ip route 22.0.0.0/24 13.0.0.2
  ip route 22.0.0.0/24 13.0.0.3
  ip route 22.0.0.0/24 13.0.0.4
 address-family ipv6 unicast
  ipv6 route 2000::/64 1001::2
  ipv6 route 2000::/64 1002::2
  ipv6 route 2000::/64 1003::2
  ipv6 route 2000::/64 1004::2
Device 2# show running-config vrfred
vrf red
  ipv6 route 2000::/64 1001::2 distance 4
