ISW Series Managed Industrial Ethernet Switch Hardware Installation Guide
> General Safety Precautions
Published January 2024
Preface
ISW-Series Switch Overview
8-port Switch Models
12-port Switch Models
28-port Switch Model
Power Supplies for Use with Your Switch
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Requirements for PoE Devices
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Mount the Switch
Connect Power Supplies, Alarm Relay, and Ground Connection
Turn on the Switch
Connect to the Management Console
Configure the Switch for Use
Monitor the Switch
System Status LEDs
Copper RJ45 Port LEDs
SFP and SFP+ Port LEDs
PoE LEDs
Reset, Upgrade or Downgrade Software
System Reset
Reset Configuration Defaults via CLI Command
Reset Configuration Defaults via Web UI
Upgrade and Downgrade Software
Important Deployment Considerations
ISW Series Technical Specifications
Power Options
Weights and Physical Measurements
Performance & Scale
CPU, Memory
Console Connector Pinouts
Standards
Environmental Specifications
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Federal Communications Commission (FCC) Notice
Follow these guidelines:
Do not try to lift objects that you think are too heavy for you.
When you install equipment in a rack, load heavier devices in the lower half of the rack first to avoid making the rack top-heavy.
Use only tools and equipment that are in perfect condition. Do not use equipment with visible damage.
Route cables in a manner that prevents possible damage to the cables and avoids causing accidents, such as tripping.
Do not place a monitor or other objects on top of the equipment. The chassis cover is not designed to support weight.
To reduce the risk of fire, use only #26 AWG or larger telecommunications line cord. Use only copper conductors.
Do not work on the system or connect or disconnect cables during periods of lightning activity.
This equipment must be grounded. Never defeat the ground conductor or operate the equipment in the absence of a suitably installed ground conductor.
