The DC power interface is a 6-pin terminal block with polarity signs on the top panel. The ISW can be powered from two power supply (input range 12V – 58V). The DC power connector is a 6-pin terminal block; there is alarm contact on the middle terminal block.
The switch can be powered from two power supplies (input range 12V – 58V). Insert the positive and negative wires into V+ and V- contacts on the terminal block respectively and tighten the wire-clamp screws to prevent the wires from being loosened.
The DC power should be connected to a well-fused power supply.
| Power Connector (6P Terminal Block) | |
| Input | DC 12-58V |
| PWR1 +/- | Power Input 1 +/- |
| PWR2 +/- | Power Input 2 +/- |
| ALM | Alarm relay output |
