The ExtremeSwitching SLX 9150 Series switches offer a versatile and efficient core/aggregation switching functionality for both campus and data center environments. The SLX 9150 Series switches run on the SLX-OS operating system.
The SLX 9150 Series switches include the following hardware features.
Model | SLX 9150-48Y | SLX 9150-48XT |
Ports | 48 1/10/25GbE SFP28 ports
48 1/10GbE 10GBaseT ports
Power Supplies | Modular 750W AC power supply (up to two PSUs)
Fan Modules | 6 fan modules
6 fan modules
Dimensions | 17.3in W / 20.9in D / 1.7in H (44.0cm / 53.2cm / 4.3cm) | 17.3in W / 20.9in D / 1.7in H (44.0cm / 53.2cm / 4.3cm) |
Performance | Line rate 4Tbps Switching Capacity (2Tbps ingress, 2Tbps egress) Average Latency: 800 ns | Line rate 2.16 Tbps Switching Capacity (1.08Tbps ingress, 1.08Tbps egress) Average Latency: 800 ns |
CPU Memory |
Packet Buffers | 32 MB | 32 MB |
Operating Conditions | 0 º - 45ºC operation 5% to 95% relative humidity, non-condensing 0 - 3000 meters‘ altitude Shock (half sine):98 m/ s2 (10 G), 11ms, 9 shocks Random vibration: 3 to 500 Hz at 1.5 G rms | 0 º - 45ºC operation 5% to 95% relative humidity, non-condensing 0 - 3000 meters‘ altitude Shock (half sine): 98 m/ s2 (10 G), 11ms, 9 shocks Random vibration: 3 to 500 Hz at 1.5 G rms |
The front panel of the SLX 9150-48Y Switch includes:
48 10/25-gigabit Ethernet ports capable of supporting passive copper SFP28 and active fiber SFP28.
Data Ports 55 and 56 are reserved.
RJ45 serial console port used to connect a terminal and perform local management.
USB port for access to external storage.
RJ45 out-of-band 10/100/1000BASE-T management Ethernet port.
LEDs to indicate port status and switch operating conditions. For a description of the LEDs and their operation, refer to the SLX 9150 Series Switch LEDs section of the guide.
The following illustration shows the front view of the SLX 9150-48Y Switch.
The following illustration shows the front view of the SLX 9150-48XT Switch.
The rear panel of both SLX 9150-48XT and SLX 9150-48Y switches include:
Two power supply bays for 750 W AC or DC power supplies.
Six bays for replaceable fan modules.
Red: front-to-back
Blue: back-to-front
The operating-system software cannot display the airflow direction.
The following illustration shows the rear view of the SLX 9150-48Y Switch.
The following illustration shows the rear view of the SLX 9150-48XT Switch.
For more device details, refer to the ExtremeSwitching SLX 9150 Technical Specifications .
