If a licensed feature is not functioning, a probable reason is that the license for that feature has not been installed correctly. Either the license was not installed, or it was installed and a required system reboot or other required action was not performed.
If you suspect a license is not properly installed, complete the following steps.
device# show license
Chassis:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
       Capacity on Demand license
       Feature name:CAPACITY_ON_DEMAND
       Capacity: 24
       License is Node-Lock and valid
       100G Port Upgrade license
       Feature name:PORT_100G_UPGRADE
       Capacity: 6
       Advanced Features license
       Feature name:ADVANCED_FEATURES
       License is Trust Based
       EULA acceptance date: Thu May 30 09:55:54 2019
After adding a Port Upgrade license, you must disable and re-enable all affected ports.
device# license add licstr "*B OXw:jFQ0IZc,t1D12:fZVuQByBOJMeqIoPhjpHK9gJLrcLzYIbEXVmDCd8N4nRyTfdxoGQI93gRS9ylO:cf00If68JA1flHZzMQs4:eiIlC,VbOpx4E6UG8YeXWcaVIBSTVv#" 2014/11/13-16:41:16, [SEC-3051], 5615, SW/0 | Active, INFO, MYSWITCH, The license key *B OXw:jFQ0IZc,t1D12:fZVuQByBOJMeqIoPhjpHK9gJLrcLzYIbEXVmDCd8N4nRyTfdxoGQI93gRS9ylO:cf00If68JA1flHZzMQs4:eiIlC,VbOpx4E6UG8YeXWcaVIBSTVv# License Added [*B OXw:jFQ0IZc,t1D12:fZVuQByBOJMeqIoPhjpHK9gJLrcLzYIbEXVmDCd8N4nRyTfdxoGQI93gRS9ylO:cf00If68JA1flHZzMQs4:eiIlC,VbOpx4E6UG8YeXWcaVIBSTVv#] For license change to take effect, it may be necessary to enable ports...
