Use the following procedure to activate the Dynamic POD feature.
The command output indicates whether a port is licensed.
The following example shows a device without any Port Upgrade license installed on an interface module. The 12 ports in the base port set are online and assigned. The remaining 2 ports are unassigned and down.
device# show ip interface brief
Flags:  I - Insight Enabled     U - Unnumbered interface
Interface              IP-Address     	Vrf                    Status                Protocol
Ethernet 0/1           unassigned       default-vrf             up                      up
Ethernet 0/2           unassigned       default-vrf             up                      up
Ethernet 0/3           unassigned       default-vrf             up                      up
Ethernet 0/4           unassigned       default-vrf             up                      up
Ethernet 0/5           unassigned       default-vrf             up                      up
Ethernet 0/49          unassigned       default-vrf            administratively down    down(No 100G/40G Port Upgrade License)
Ethernet 0/50          unassigned       default-vrf            administratively down    down(No 100G/40G Port Upgrade License)
		  device# show interface ethernet 0/49
  Ethernet 0/49 is down, line protocol is down (No 100G/40G Port Upgrade License)
  Hardware is Ethernet, address is 0005.1eb6.0a25
  Current address is 0005.1eb6.0a25
  Tracking status: Disabled
  Tracked interfaces: None
  Pluggable media present, Media type is sfp
  Interface index (ifindex) is 1744896001
  MTU 2500 bytes
  LineSpeed: Auto - 10000 Mbit, Duplex: Full
  Flowcontrol rx: on, tx: on
