Depending on the license type, you may be prompted to clear license-dependent configurations, reload the switch, or disable and re-enable the chassis or specific ports. The following table indicates the minimal steps you may need to take to remove specific licenses. Take the appropriate action as indicated by the command output.
				   License  |
				   Description  |
				   ADVANCED_FEATURES  |
				   All features that have been enabled that depend on the Advanced Features license (MPLS, BGP EVPN, Guest OS for TPVM, etc.) must be disabled first.  |
				   CAPACITY_ON_DEMAND  |
				   Port reservations for non-Base ports provisioned by the license must be released first.  |
				   PORT_100G_UPGRADE  |
				   PORT_10G_UPGRADE  |
				   PORT_100G_40G_UPGRADE  |
For some licensed features, you must clear all configurations related to the feature before you can remove the license for that feature. Some features may require you to disable and re-enable selected ports or the entire switch.
Refer to the console output for other specific requirements.
Do the following to remove an installed (non SAU) license.
