Use the following procedures to install licenses on a SLX-OS device.
device# license add SCP-URL scp://fvt:mypassword@10.70.5.58//users/home40/"pray4green/ 20141113164801170PORT_UPGRADE.xml License Added [*B OXw:jFQ0IZc,t1D12:fZVuQByBOJMeqIoPhjpHK9gJLrcLzYIbEXVmDCd8N4nRyTfdxoGQI93gRS9ylO:cf00If68JA1flHZz MQs4:eiIlC,VbOpx4E6UG8YeXWcaVIBSTVv#] For license change to take effect, it may be necessary to enable the ports...
Depending on the license type, you may be prompted to reload the device or to disable and re-enable the chassis or specific ports. The following table indicates the minimal steps you may need to take to make the installed features fully functional after the license add operation is complete. Take the appropriate action as indicated by the command output.
						 License  |
						 Description  |
						 PORT_100G_40G_UPGRADE  |
						 For all applicable platforms, may require enabling the added ports or disabling and then re-enabling the added ports.  |
						 PORT_10G_UPGRADE  |
						 PORT_100G_UPGRADE  |
						 CAPACITY_ON_DEMAND  |
						 For all applicable platforms, requires explicitly manually reserving ports using config license dpod CLI command and then may require enabling the added ports or disabling and then re-enabling the added ports.  |
						 ADVANCED_FEATURES  |
						 The End-User License Agreement (EULA) must be accepted through the license eula CLI commands before the system can support the licensed capabilities for the SAU license.  |
