Configuring ingress tunnel accounting
This section explains how to configure ingress tunnel accounting at Link Switch Routers (LSR).
  1. Enter router mpls command to configure MPLS in global configuration mode.
  2. Enter policy command to set the MPLS policy.
  3. Enter ingress-tunnel-accounting command to configure ingress tunnel accounting at Link Switch Routers (LSR).
The following example shows how to configure ingress tunnel accounting at Link Switch Routers (LSR).
device# configure
device(config)# router mpls
device(config-router-mpls)# policy
device(config-router-mpls-policy)# ingress-tunnel-accounting
