Configuring the RSVP refresh multiple
The refresh multiple is the number of refresh intervals that must elapse without a refresh message before a path state or resource reservation times out.
When refresh messages are not received, RSVP path states and resource reservations are removed from the routers in an LSP. By default, the device waits the length of three refresh intervals; when no refresh message is received by the end of that time, the path state or resource reservation is removed.
The user can set the refresh multiple from zero through 65535 intervals.
Complete the following steps to set the refresh multiple to five intervals.
  1. Enable the device for configuration.
    device# configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enable configuration of RSVP parameters
    device(config-router-mpls)# rsvp
  4. Configure the refresh multiple.
    device(config-router-mpls-rsvp)# refresh-multiple 5
    The refresh multiple is the number of unresponsive paths or reservations before time runs out. In this example, the refresh multiple is configured to 5.
The following example shows setting the refresh multiple to 5.
device# configure
