Setting the From-Address for Dynamic Bypass LSPs
The user can configure an interface level from IP address when creating a dynamic bypass LSP for the protected MPLS interface . Use the dynamic bypasses from address as the IP address.
To set the from address for dynamic bypass LSPs, complete the following steps.
  1. Enable the device for configuration.
    device>configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enable MPLS-capable interfaces and specify the selected interface. In this example, the selected Ethernet interface is 0/8.
    device(config-router-mpls)# mpls-interface ethernet 0/8
  4. Enable the interface level dynamic bypass.
    device(config-router-mpls-if-ethernet-0/8)# dynamic-bypass
  5. Configure the from address. In this example, the from address configuration is 11.11.11.11.
    device(config-router-mpls-if-ethernet-0/8-dynamic-bypass)# from 11.11.11.11
The following example combines the steps above to configure the from command IP address for dynamic bypass LSPs to 11.11.11.11.
device>configure
