Entering help after a specific command will display usage and syntax information for that command. This example shows how to display context-sensitive help for the set length command:
System(rw)->set length help
Command: set length Number of lines
Usage: set length <screenlength>
screenlength Length of the screen (5..512, 0 to disable 'more')
Print
this page
Email this topic
Feedback
