Installing Hyperglance
This section details the installation and configuration settings required to successfully deploy Hyperglance. You must have a working centOS6.4 VM installed on an ESXi VM server with OneController virtual tenant network (VTN) running.
Hyperglance is based off a server/client architecture with the server communicating directly with the ODL controller and the client communicating directly with the Hyperglance server. Two interfaces can be used if desired. You can configure an “inside” static interface to interconnect to the OneController and an “outside” interface interconnecting the Hyperglance client application. Hyperglance communicates with OneController to populate its tables.
