Enabling and Configuring OpenFlow
This section demonstrates how to successfully configure OpenFlow
on ExtremeXOS operating system. You must have previously installed the OpenFlow XMOD
file and enabled it with a license key.
For complete OpenFlow configuration options, see the ExtremeXOS User Guide at www.extremenetworks.com/documentation.To enable and configure OpenFlow:
- Configure the VLANs that you wish OpenFlow to be enabled on.
- Type the command configure access-list width double.
- Enable OpenFlow by entering the command enable openflow.
Configure the OpenFlow OneController parameters on
the switch:
- Type the command configure openflow controller primary out-of-band active ipaddress x.x.x.x vr-x.
- Type the command enable openflow vlan vlanx (enables OpenFlow on your selected VLANs).
- Type the command show openflow. The switch should show a status of ACTIVE if the switch is connected to the OneController. A status of BACKOFF defines an unconnected switch.
