The TPVM package is available separately from the SLX-OS software, and may be downloaded from the SLX-OS Release Server. This decoupling enables faster turnaround on enhancements and bug fixes, while reducing the file size of the SLX-OS distribution. (Prior to SLX-OS 18r.2.00, the TPVM package was released in conjunction with the SLX-OS packages.)
Important
The installation is disruptive, and any data saved on the TPVM partition is erased. You must save any data manually before executing the tpvm install command.<slxos release dir>/SWBD2900/tpvm-4.0.0-3.amd64.deb
tpvm-4.0.0-3.amd64.deb and
tpvm-3.0.0-0.amd64.deb.The following table lists the TPVM package names and locations for relevant SLX-OS releases.
| SLX-OS release | TPVM package name | TPVM package location |
| slxos16r.x.xx | vm-swbd2900-1.0.0-1.i386.deb | <slxos release dir>/SWBD2900/vm-swbd2900-1.0.0-1.i386.deb |
| slxos17r.1.xx | vm-swbd2900-1.0.0-1.i386.deb | <slxos release dir>/SWBD2900/vm-swbd2900-1.0.0-1.i386.deb |
| slxos17r.2.xx | vm-swbd2900-1.0.0-1.amd64.deb | <slxos release dir>/SWBD2900/vm-swbd2900-1.0.0-1.amd64.deb |
| slxos18r.1.xx | vm-swbd2900-1.0.0-1.amd64.deb | <slxos release dir>/SWBD2900/vm-swbd2900-1.0.0-1.amd64.deb |
| slxos18r.2.xx | tpvm-2.0.0-0.amd64.deb | <TPVM release url>/tpvm2.0.0/tpvm-2.0.0-0.amd64.deb (see NOTE) |
| slxos 20.1.1 | tpvm-3.0.0-0.amd64.deb | <TPVM release url>/tpvm3.0.0/tpvm-3.0.0-0.amd64.deb |
| slxos 20.1.2 | tpvm-4.0.0-3.amd64.deb | <TPVM release url>/tpvm4.0.0/tpvm-4.0.0-3.amd64.deb |
Removed from SLX-OS release folder and posted on release server for access through separate URL.
