Extreme SLX-OS Management Configuration Guide, 20.1.2a
Guest OS for TPVM
Insight Interface and TPVM
> Insight interface
Published June 2020
Preface
Getting Help
Providing Feedback
About This Document
Supported Hardware
What‘s New in this Document
Configuration Files
Displaying configurations
Backing up configurations
Configuration restoration
Managing flash files
Rebooting the device
Session connection
Telnet
Shutting down and re-enabling the Telnet service
SSH
Feature support for SSH
Shutting down and re-enabling the SSH service
Configuring a login banner
Configuring a static ethernet address
Port management
SLX 100G ports
Configuring breakout mode
Port flap dampening
Port transition hold timer
Link fault signaling
Interface Ethernet ports
Displaying device interfaces
Chassis and host names
System clock
Setting the clock
Management VRFs
VRF reachability
Zero Touch Provisioning
Using ZTP
ZTP configuration
Enhanced Zero Touch Provisioning (ZTP+)
Firmware validation
Configuration
MAC address aging
Hardware profiles
TCAM profiles
Specifying a TCAM profile
TCAM sharing
Enabling TCAM sharing
Counter profiles
Specifying a counter profile
FIB compression
Configuring FIB compression
Executing scripts from SLX-OS
Guest OS for TPVM
VM Access Management
VM access
SLX-OS CLI to VM access
Serial Console Access
Accessing the SLXVM1 Host-OS shell from the SLX-OS CLI
Serial console to VM access
TPVM Console Access
TVPM address assignment
TPVM on the SLX 9150 series
Insight interface
Insight Interface Data Path
Inbound ACL-based mirroring
QoS egress scheduling
QoS rate shaping
SLX-OS VM commands
TPVM
perfSONAR
ARP sponge
TPVM Management
TPVM Package Information
Using the tpvm command
Using the tpvm config Command
Using tpvm deploy
Docker containers
Linux containers
Network Time Protocol (NTP)
Configuring NTP
Authenticating an NTP server
SNMP
SNMP overview
Basic SNMP operation
SNMP community strings
SNMP groups
SNMP users
SNMP views
SNMP server hosts
SNMP source interface
Configuring SNMPv2
Configuring SNMPv3
LLDP
LLDP overview
Layer 2 topology mapping
Configuring and managing LLDP
Disabling LLDP globally
Configuring LLDP profiles
Displaying LLDP information
Account and Password Recovery
(DNX devices) Recover the root login account
(DNX devices) Recover the root password
(XGS devices) Recover the root password
Python overview
Python scripts
Python scripts and run-logs
Event-handler script
Python event-management
Activating an event-handler
Configuration Rollback
Configuring rollback
Insight interface
