The SLX 9150 and SLX 9250 use directly connected, dedicated internal ethernet ports for TPVM access. These ports are used exclusively for VM access and are not accessible from the command line interface. Use the following steps to configure a port channel to access the Insight Interface on the SLX 9150 and SLX 9250.
  1. Enter global configuration mode.
    device# configure terminal
  2. In global configuration mode, specify a port-channel. You can create a new port-channel or use an existing unconfigured port-channel. The Insight Interface can only be configured on one port-channel
    device(config)# interface port-channel 50
  3. In interface subtype configuration mode, enter the insight enable command.
    device(config-Port-channel-50)# insight enable
  4. Set the port ip-address.
    device(config-Port-channel-50)# ip address 10.0.0.1/24
  5. Enable the interface.
    device(config-Port-channel-50)# no shutdown
  6. Use the show interface port-channel and the show port-channel commands to confirm the configuration, as in the following example.
    device# show interface port-channel 50
    Port-channel 50 is up, line protocol is up
    Insight mode is enabled
    Hardware is AGGREGATE, address is f46e.959f.1af5
    	Current address is f46e.959f.1af5
    Interface index (ifindex) is 671088690 (0x28000032)
    Minimum number of links to bring Port-channel up is 1
    MTU 9216 bytes
    LineSpeed Actual     : 10000 Mbit
    Allowed Member Speed : 10000 Mbit
    Priority Tag disable
    Forward LACP PDU: Disable
    Route Only: Disabled
    Tag-type: 0x8100
    Last clearing of show interface counters: 4d18h22m
    Queueing strategy: fifo
    FEC Mode - Disabled
    Receive Statistics:
    	0 packets, 0 bytes
    	Unicasts: 0, Multicasts: 0, Broadcasts: 0
    	64-byte pkts: 0, Over 64-byte pkts: 0, Over 127-byte pkts: 0
    	Over 255-byte pkts: 0, Over 511-byte pkts: 0, Over 1023-byte pkts: 0
    	Over 1518-byte pkts(Jumbo): 0
    	Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0
    	Errors: 0, Discards: 0
    Transmit Statistics:
    	12 packets, 5589 bytes
    	Unicasts: 0, Multicasts: 12, Broadcasts: 0
    	Underruns: 0
    Rate info:
    	Input 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
    	Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
    Route-Only Packets Dropped: 0
    Time since last interface status change: 00:00:25
