The Redundant Management Interface feature provides fault tolerance for the management path.
Redundant Management is supported on the SLX-9250 only.device# configure device(config)# interface management 0 device(config-Management-0)# ip address dhcp device(config-Management-0)# no shut device(config-Management-0)# exit
device(config)# interface ethernet 0/15 device(conf-if-eth-0/15)# redundant-management enable device(conf-if-eth-0/15)# no shut device(conf-if-eth-0/15)# exit
(device)# show interface Management 0 interface Management 0 line-speed actual "1000baseT, Duplex: Full" oper-status up ip address "static 10.24.12.89/22" ip gateway-address 10.24.12.1 ipv6 ipv6-address [ ] ipv6 ipv6-gateways [ ] redundant management port 0/15
(device)# show interface ethernet 0/15 Ethernet 0/15 is admin down, line protocol is down (admin down) Redundant management mode is enabled Hardware is Ethernet, address is 609c.9f5a.a35f Current address is 609c.9f5a.a35f Pluggable media not present Description: Insight port Interface index (ifindex) is 202350592 (0xc0fa000) MTU 9216 bytes Maximum Speed : 10G LineSpeed Actual : Nil LineSpeed Configured : Auto, Duplex: Full Priority Tag disable Forward LACP PDU: Disable Route Only: Disabled Tag-type: 0x8100 Last clearing of show interface counters: 00:01:13 Queueing strategy: fifo FEC Mode - Disabled Receive Statistics: 0 packets, 0 bytes Unicasts: 0, Multicasts: 0, Broadcasts: 0 64-byte pkts: 0, Over 64-byte pkts: 0, Over 127-byte pkts: 0 Over 255-byte pkts: 0, Over 511-byte pkts: 0, Over 1023-byte pkts: 0 Over 1518-byte pkts(Jumbo): 0 Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0 Errors: 0, Discards: 0 Transmit Statistics: 0 packets, 0 bytes Unicasts: 0, Multicasts: 0, Broadcasts: 0 Underruns: 0 Errors: 0, Discards: 0 Rate info: Input 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate Route-Only Packets Dropped: 0 Time since last interface status change: 00:01:13
