The following table includes description of changes in functionality for the current release.
Feature | Description | Described in |
Auto-Persistence of Configuration Data | Configuration Data automatically persists in a single database and is replayed when the system reboots. | Auto-Persistence of Configuration Data |
Reboot into Maintenance Mode | The config-system-maintenance command provides the enable-on-reboot parameter, allowing the device to enter maintenance mode upon reboot. Use of this command does not disturb the current operation of the device. | Rebooting into Maintenance Mode |
Redundant Management Interface | The Redundant Management Interface feature provides fault tolerance for the management path. | Redundant Management Interface |
NTP Server | NTP Server command reconfiguration after SLXOS downgrade. | Configuring NTP |
