TPVM has Ethernet 0 and 1 interfaces. Ethernet 0 (eth0) is enabled and its IP address is configured using DHCP.
On the SLXVM, the show tpvm ipaddr command configures the address.
If DHCP is not available, you can use the serial console to log in as root, and use standard Ubuntu (18.04.4 LTS) commands to configure the IP address for eth0 interface.
Eth1 is connected to the Insight interface and allows packet monitoring.
