Defining Authentication by Captive Portal
for the Third-party AP WLAN Service
802.1x Authentication is not
supported directly by the wireless controller. However, this type of authentication can
be supported by the actual third-party AP. All other options for authentication are
supported at the controller.
- On the WLAN configuration window for the
third-party WLAN (Wireless Local Area Network) Service, click the Auth
& Acct tab.
- In the Authentication
Mode drop-down list, click Internal or External, and then click Configure.
- Define the Captive Portal configuration as described in Configuring Captive Portal for Internal or External Authentication.
