Edit or Delete a Topology Group
            To modify or delete a topology group:
                From the top menu, click
                        VNS.
                In the left pane, click
                        Topologies and click on a
                    topology group to edit or delete. (Do not select the checkbox.)
                To edit the group, in the Topologies pane, click
                        Edit.
The Topology list is populated with available topologies.
                 Check topology boxes to add topologies to the
                    group. Clear the checkboxes to remove topologies from the group.
                To delete the topology group that you have open,
                    click the Delete
                    button.
When a topology group is deleted, only the group is deleted, not the
                    topologies it contains.
                Click Save.
                You can also delete the topology group from the Topologies
                    tab.
                        From the top
                            menu, click VNS.
                        From the left pane, click Topologies.
                        Select the checkbox for the topology group to delete and click
                                Delete Selected.
                        Click Save.
