Camera UI Basic Functions
Configure the AP3916ic camera using the web user interface. The AP3916ic web user interface is divided into the following tabs:
System
Status Displays status information about the system, network, and video streams.
Sample System Status
Graphics/camera_web_ui_status.png
Time Date/Time settings for the camera.
Sample Manual Time settings
Graphics/camera_web_ui_manual_time.png
Sample NTP Server Settings
Graphics/camera_web_ui_NTP_time.png
Firmware Browse to the camera image (.dlf file) and apply the image.
Camera firmware is distributed and managed from the controlling ExtremeWireless appliance. If GTAC Support determines that a specific firmware version is required on your device, the on-board firmware upload functionality can be used to install the image. GTAC will provide the necessary firmware (.dfl) file.
Backup Save camera settings to a backup file or restore settings from an existing backup file.
Sample Backup /Restore Settings
Graphics/camera_web_ui_backup.png
Reset to Default/Reboot
Reset Camera Rest camera to factory default settings. Backup current settings before resetting to factory default settings.
Reboot Camera Restarts the camera. The current camera settings are retained after a camera restart.
Network. Configure network settings for the camera port.
IP Configuration Settings
Sample IP Configuration Settings
Graphics/camera_web_ui_network.png
Dynamic IP (DHCP) is the default network Mode.
Universal Plug and Play (UPnP)
Sample Discovery Settings: UPnP
Graphics/camera_web_ui_upnp.png
Media. Configure settings for: video, camera, advanced settings, privacy mask, and audio.
Video
Sample Video Configuration Settings
Graphics/camera_web_ui_video.png
Camera The video feed assumes a ceiling mount default orientation. When installing the AP in any other orientation, adjust the video feed accordingly. For example,when the AP is installed as a desk-mount, the video Mirror/Flip setting should be Flip.
Sample Camera Settings
Graphics/camera_web_ui_camera.png
Advanced
Sample Camera Advanced Settings
Graphics/camera_web_ui_advanced.png
Audio
Sample Camera Audio Settings
Graphics/camera_web_ui_audio.png
User Management. Add and delete user accounts, change user settings, and change user password.
User List
User Management Settings
Graphics/camera_web_ui_user_management.png
You cannot delete the Administrator account.
