4220 Technical Specifications
This section lists technical specifications for the hardware products described in this document.
Table 1. External Interfaces
Switch ModelInterfaces
4220-12T-4X
  • 12 x 10/100/1000Base-T ports
  • 4 x 1/10Gb SFP+ uplink/stacking ports (unpopulated)
  • 1 x 10/100/1000BASE-T out-of-band management port
  • 1 x Serial console port (RJ-45)
  • 1 x USB A port
  • 1 x USB Micro-B console port
Note: Switch Engine and Fabric Engine supported
4220-12P-4X
  • 12 x 10/100/1000Base-T 802.3at (30W) PoE ports
  • 1 x USB A ports
4220-24T-4X
  • 24 x 10/100/1000Base-T ports
  • 1 x USB A ports
4220-24P-4X
  • 24 x 10/100/1000Base-T 802.3at (30W) PoE ports
  • 4 x 1/10Gb uplink/stacking ports (unpopulated)
  • 1 x USB A ports
4220-48T-4X
  • 48 x 10/100/1000Base-T ports
  • 1 x USB A ports
Note: Switch Engine supported only
4220-48P-4X
  • 48 x 10/100/1000Base-T 802.3at (30W) PoE ports
  • 1 x USB A ports
4220-4MW-8P-4X
  • 4 x 1G/2.5G/5GBaseT 802.3bt (90W) PoE ports
  • 8 x 10/100/1000Base-T 802.3at (30W) PoE ports
  • 1 x USB A ports
4220-4MW-20P-4X
  • 20 x 10/100/1000Base-T 802.3at (30W) PoE ports
  • 1 x USB A ports
4220-8MW-40P-4X
  • 8 x 1G/2.5G/5GBaseT 802.3bt (90W) PoE ports
  • 40 x 10/100/1000Base-T 802.3at (30W) PoE ports
  • 1 x USB A ports
4220-8X
  • 8 x 1/10Gb SFP+ ports (unpopulated)
  • 1 x USB A ports
Table 2. Weights and Dimensions
Part NumberWeightPhysical Dimensions
4220-12T-4X5.5 lb / 2.52 kg12.0 in W / 1.7 in H / 10.3 in D
305 mm / 44 mm / 261 mm
4220-12P-4X6.8 lb / 3.11 kg
4220-24T-4X7.0 lb / 3.16 kg17.36 in W / 1.7 in H / 10.0 in D
441 mm / 44 mm / 254 mm
4220-24P-4X9.6 lb / 4.37 kg17.4 in W / 1.7 in H / 13.0 in D
441 mm / 44 mm / 330 mm
4220-48T-4X10.0 lb / 4.53 kg
4220-48P-4X11.2 lb / 5.09 kg
4220-4MW-8P-4X7.1 lb / 3.23 kg12.0 in W / 1.7 in H / 10.3 in D
4220-4MW-20P-4X10.6 lb / 4.83 kg17.4 in W / 1.7 in H / 13.0 in D
4220-8MW-40P-4X11.9 lb / 5.41 kg
4220-8X5.2 lb / 2.37 kg12.0 in W / 1.7 in H / 10.3 in D
Table 3. Redundant Power Supplies
RPS-5505.0 lb / 2.26 kg12.6 in W / 1.7 in H / 7.9 in D
320 mm / 43.5 mm / 200 mm
RPS-9505.4 lb / 2.43 kg
Redundant Power Supply Cables and Bluetooth Adapter
RPS-CBL-1M1.3 lb / 0.6 kg39.4 in W / 0.9 in H / 3.1 in D
1000 mm / 24 mm / 80 mm
RPS-CBL-1M-2x71.0 lb / 0.5 kg39.4 in W / 0.9 in H / 2.4 in D
1000 mm / 23 mm / 62 mm
Console Cables
Part NumberDescription
XN-RJ45-DB9-CONSOLE-CBLRJ45 to DB9 Console cable (6ft)
XN-RJ45-USBA-CONSOLE-CBLRJ45 to USBA Console cable (6ft)*
XN-RJ45-USBC-CONSOLE-CBLRJ45 to USBC Console cable (6ft)*
* The cable might require an FTDI software driver on some operating systems.
