Turn on the Switch
Use the following instructions to turn on the switch
The switch does not have a power button, so connecting the power cable at both ends turns the switch on.
Connect AC Power
An AC power cord is not included with the AC power supply. You can purchase AC power cords for use in the US and Canada from Extreme Networks or from your local supplier. The cord must meet the requirements listed in Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
To turn on the switch, connect one end of the power cord to the AC power input socket on the device and connect the other end to an AC power outlet.
The grounding connection in the power receptacle and in the power cord properly ground the power supply and extend that grounding to the switch.
When the power supply LED has turned green, follow the instructions in Activate and Verify the Switch.
