Install Your Switch
Before you attempt to install or remove an Extreme Networks switch, read the precautions in Safety Considerations for Installation.
If you are installing switches for use in a stacking configuration, read Build Stacks before you install the switches.
Extreme Networks switches fit into standard 19-inch equipment racks.
A four-post rack-mounting kit is provided with the switch. A two-post kit can be ordered separately.
The provided rack-mounting brackets attach to the front of the switch and are adaptable to either a front-mount or mid-mount installation. Optional rear-mounting brackets are also included for four-post racks or cabinets
The installation process includes the following tasks:
Table 1. Switch Installation Tasks
StepProcedureDescription
1What You Will Need for the Installation Prepare to install the switch
2Attach the Switch to a Rack or Cabinet Mount the switch, or install the switch in the rack.Install the switch in the rack.
4Install Optional Components Install optional components: optical transceivers and cables.
5Install Internal Power Supplies
6Connect the Switches to Form the Stack Ring Connect stacking cables for a stacked configuration.
7Connect Network Interface Cables Connect network interface cables.
8Turn on the Switch Power up the switch.
9Activate and Verify the Switch Perform initial network connection and configuration.
