Power Specifications
Internal Fixed and Optional External Redundant Power Supply
Switch ModelInternal Fixed PSU - Max PowerSecondary PSU
4220-12T-4X65W–
4220-12P-4X370W–
4220-24T-4X65W–
4220-24P-4X370W–
4220-48T-4X150W–
4220-48P-4X550W–
4220-4MW-8P-4X370W–
4220-4MW-20P-4X550WRPS-550W
4220-8MW-40P-4X950WRPS-950W
4220-8X65W–
Max PoE Power Budget
Switch Model With Internal Fixed PSU With Internal Fixed PSU + 920W PSU With Internal Fixed PSU + 1200W PSU With Internal Fixed PSU + 2000W PSU
4120-24MW-4Y (100-120VAC) 680W 1440W 1380W Not Supported
4120-48MW-4Y (100-120VAC) 640W Not Supported 1340W 1230W
4120-24MW-4Y (200-240VAC) 680W 1440W 1540W Not Supported
4120-48MW-4Y (200-240VAC) 980W Not Supported 1780W 2180W
Minimum/Maximum Power Consumption and Heat Dissipation
Switch Model Minimum Power Consumption (W) Minimum Heat Dissipation (BTU/hr) Maximum Power Consumption (W)* Maximum Heat Dissipation (BTU/hr)**
4220-12T-4X 12 41 26 89
4220-12P-4X 17 58 166 142
4220-24T-4X 15 50 31 104
4220-24P-4X 20 68 252 195
4220-48T-4X 28 96 52 177
4220-48P-4X 30 103 470 340
4220-4MW-8P-4X 19 64 304 219
4220-4MW-20P-4X 22 73 458 300
4220-8MW-40P-4X 35 118 899 542
4220-8X 11 38 30 103
