4220 Series Installation Guide
> Remove and Replace Components
Extreme Networks, Inc. July 01, 2026
Abstract
Introduction to the 4220 Series Installation Guide
New in this Guide
4220 Cloud Managed Switch Overview
4220-12T-4X Switch Features
4220-12P-4X Switch Features
4220-24P-4X Switch Features
4220-24T-4X Switch Features
4220-48P-4X Switch Features
4220-48T-4X Switch Features
4220-4MW-20P-4X Switch Features
4220-4MW-8P-4X Switch Features
4220-8MW-40P-4X Switch Features
4220-8X Switch Features
Manage Your Switch
Universal Ethernet Ports
Redundant Power Supplies for Use with Your Switch
Build Stacks
Introduction to Stacking
Build Basic Stacks
Slot Numbers in Stacks
SummitStack Topologies
SummitStack Terms
Plan to Create Your Stack
Enable and Disable the Stacking Support Option
Recommendations for Placing Switches for Stacked Operation
Recommendations for Configuring Stacks
Combine Switches from Different Series
Select Stacking Cables
Use the Extreme Stacking Tool
Set up the Physical Stack
Connect the Switches to Form the Stack Ring
Examples of Valid Stacking Configurations
Example: Basic Stack with Four Switches
Example: Basic Stack with Eight Switches
Example: Stacked Switches across Several Racks
Connect Your Stack to the Management Network
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Requirements for PoE Devices
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Install an External Redundant Power Supply
Install Optional Components
Turn on the Switch
Log In for the First Time on Switch Engine
Change the Switch OS via the Bootloader Menu
Change the Switch OS via the Startup Menu
Log In for the First Time on Fabric Engine
Remove a Switch from a Two-Post Rack
Disconnect the RPS Cable and the AC Power Cord
Monitor the Switch
4220 Series Switch LEDs
External Redundant Power Supply LEDs
Technical Specifications
4220 Technical Specifications
Acoustics
Memory
Mean Time Between Failures (MTBF)
Power Specifications
Environmental
Standards
Safety Information
General Safety Precautions
Maintenance Safety
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
Regulatory Information
CE statement
EMC Warnings
China and Taiwan: Restriction of Hazardous Substances (ROHS)
Canadian requirements
Australia (RCM)
Federal Communications Commission (FCC) Notice
Germany statement
KCC statement (Republic of Korea)
Japan (VCCI Class A)
Japan power cord
Use the information in the following topics to remove or replace components.
Section contents:
