5320 Series Technical Specifications
External Interfaces
Switch ModelInterfaces
5320-16P-2MXT-2X
16 x 10/100/1000BASE-T 802.3at (30W) ports
  • Full / Half-Duplex (autosensing)
2 x 1/2.5/5/10GBase-T uplink ports
2 x 10Gb SFP+ uplink ports
Fanless model
1 x Serial console port (RJ-45)
1 x USB A ports for management or external USB flash
1 x USB-C console port
5320-16P-4XE
  • MACsec-capable
4 x 1/10Gb SFP+ uplink ports (includes 2 x Stacking ports)
  • MACsec-capable
1 x USB Micro-B console port
5320-16P-4XE-DC
  • MACsec-capable
  • MACsec-capable
5320-24T-8XE
24 x 10/100/1000BASE-T ports
  • Full/Half-Duplex (autosensing)
  • MACsec-capable
8 x 1/10Gb SFP+ uplink ports (includes 2 x Stacking ports)
  • MACsec-capable
  • 100Mb operation supported on last 4 uplink ports
5320-24P-8XE
24 x 10/100/1000BASE-T 802.3at (30W) ports
  • MACsec-capable
  • MACsec-capable
5320-48T-8XE
48 x 10/100/1000BASE-T ports
  • MACsec-capable
  • MACsec-capable
5320-48P-8XE
48 x 10/100/1000BASE-T 802.3at (30W) ports
  • MACsec-capable
  • MACsec-capable
5320-24T-4X-XT
1 x 10/100/1000BASE-T out-of-band management port
0°C to 60°C operating temperature range
5320-24T-24S-4XE-XT
  • MACsec-capable
24 x 100Mb/1Gb SFP uplink ports
  • MACsec-capable
  • MACsec-capable
Weights and Dimensions
Switch ModelWeightPhysical Dimensions
5320-16P-2MXT-2X3.3 kg (7.3 lb.)
Height: 43.2 mm (1.7 in.)
Width: 269.2 mm (10.6 in.)
Depth: 236.2 mm (9.3 in.)
5320-16P-4XE3.0 kg (6.6 lb.)
Width: 309.9 mm (12.2 in.)
Depth: 299.7 mm (11.8 in.)
5320-16P-4XE-DC3.0 kg (6.6 lb.)
5320-24T-8XE 3.7 kg (8.2 lb.)
Width: 439.4 mm (17.3 in.)
Depth: 279.4 mm (11.0 in.)
5320-24P-8XE4.0 kg (8.8 lb.)
5320-48T-8XE4.2 kg (9.3 lb.)
5320-48P-8XE5.0 kg (11.0 lb.) Height: 43.2 mm (1.7 in.)
Depth: 330.20 mm (13.0 in.)
5320-24T-4X-XT3.2 kg (7.1 lb.)
Height: 43.5 mm (1.7 in.)
Width: 441.0 mm (17.3 in.)
Depth: 253.8 mm (10.0 in.)
5320-24T-24S-4XE-XT4.0 kg (8.8 lb.)
Weights and Dimensions of Rack Mount Kits
Rack Mount KitsWeightPhysical Dimensions
XN-2P-RMKIT-006
(for models 5320-48T-8XE, 5320-48P-8XE, 5320-24T-8XE, and 5320-24P-8XE)
0.2 kg (0.44 lb.)Height: 20.3 mm (0.8 in)
Width: 43.2 mm (1.7 in)
Depth: 50.8 mm (2 in)
XN-2P-RMKIT-007
(for models 5320-16P-4XE and 5320-16P-4XE-DC)
0.52 kg (1.15 lb.)Height: 50.8 mm (2 in)
Width: 85.6 mm (3.4 in)
Depth: 88.1 mm (3.5 in)
XN-2P-RMKIT-011
(for models 5320-16P-4XE and 5320-16P-4XE-DC.)
0.16 kg (0.35 lb.)Height: 43.4 mm (1.7 in)
Width: 50.8 mm (2 in)
Depth: 85.6 mm (3.4 in)
XN-2P-RMKIT-012
(for model 5320-16P-2MXT-2X)
8.55 kg (18.8 lb.)Height: 58.9 mm (2.32 in)
Width: 123.1 mm (4.85 in)
Depth: 160 mm (6.3 in)
XN-DIN-MT-002
0.77 kg (1.7 lb.)Height: 28.9 mm (1.14 in)
Width: 75.9 mm (2.99 in)
Depth: 104.1 mm (4.1 in)
XN-UTMKIT-001
10.9 kg (24.1 lb.)Height: 28.9 mm (1.14 in)
XN-WMKIT-002
2.97 kg (6.6 lb.)Height: 28.9 mm (1.14 in)
Console Cables
Part NumberDescription
XN-RJ45-DB9-CONSOLE-CBLRJ45 to DB9 Console cable (6ft)
XN-RJ45-USBA-CONSOLE-CBLRJ45 to USBA Console cable (6ft)*
XN-RJ45-USBC-CONSOLE-CBLRJ45 to USBC Console cable (6ft)*
* The cable might require an FTDI software driver on some operating systems.
