System status LEDs are located on the front of the switch. The following table describes the colors and the states for the LEDs.
Label or Type | Color/State | Meaning |
PSU1, PSU2 (Power Supplies) | Steady green | PSU is installed and providing power |
Steady amber | PSU is installed but input power is disconnected or unit fault detected | |
Off | PSU is not installed | |
FAN | Steady green | All fans operating normally |
Steady amber | A fan has been removed or fault detected | |
Off | No power to fan modules | |
SYS (System) | Steady green | System loaded properly and is ready |
Steady amber | Either the PSU or fan or both are faulty, not present, or the system has not loaded properly | |
Off | CPU power is off | |
PWR (Power) | Steady green | Normal operation |
Blinking green | System in reset | |
Off | Unit not operational | |
SECURE | Steady blue | Authentication complete |
Very slow blinking blue (0.25Hz) | Bypass authentication (debug only) | |
Fast blinking blue (4Hz) | Authentication failed | |
Slow blinking blue (1Hz) | Authenticating or updating images | |
Off | Authentication begin or fault |
