If your device does not come with an installed internal power supply, you can install one or two power supplies. All installed power supplies must have the same airflow direction (front-to-back or back-to-front) and must also match the airflow direction of the fan modules.
If the power supply module has a red tab, the airflow is front-to-back. The fan module may be labeled Air Out.
If the power supply module has a blue tab, the airflow is back-to-front. The fan module may be labeled Air In.
The following 800 W AC or DC internal power supply units (PSUs) are available for the switch:
For installation instructions, see Replace Internal Power Supplies.
The following 1600 W AC or DC internal power supply units (PSUs) are available for the switch:
