For switches with replaceable fan modules, refer to the following information to replace the fan modules.
Images in this topic might show switches that are not identical to the ones you are using. However, the procedure for replacing a fan module is the same for all Extreme Networks switches.
Read all of the information in this chapter thoroughly before attempting to replace a fan module.Section contents:
