The following table contains external interfaces and weights and dimensions information for 7830 Series switches.
| Interfaces | Description |
| Ports |
| Power Supplies |
| Fan Tray |
| Dimensions |
| Weight |
| Model | Weight | Dimensions |
| 7830-VIM-8DE |
1.65Kg (3.64lb) | 190.25mm W x 41.4mm H x 279.91mm D (7.49in W x 1.63in H x 11.02in D) |
| 7830-VIM-16CE | 1.43kg (3.15lb) | 190.25mm W x 41.4mm H x 279.91mm D (7.49in W x 1.63in H x 11.02in D) |
| 7830-VIM-24CE | 1.44kg (3.17lb) | 190.25mm W x 41.4mm H x 279.91mm D (7.49in W x 1.63in H x 11.02in D) |
| 7830-VIM-24YE |
1.36kg (2.99lb) | 190.25mm W x 41.4mm H x 279.91mm D (7.49in W x 1.63in H x 11.02in D) |
XN-FAN-007-FB: Fan unit, front-to-back or XN-FAN-007-BF: Fan Unit back-to-front |
0.55kg (1.21lb) | 80mm W x 83.1mm H x 100.58mm D (3.15in W x 3.27in H x 3.96in D) |
| XN-ACPWR-2400W-FB: PSU, front-to-back XN-ACPWR-2400W-BF: PSU, back-to-front | 0.95kg (2.09lb) | 73.66mm W x 40.13mm H x 185.17mm D (2.9in W x 1.58in H x 7.29in D) |
| XN-DCPWR-2400W-FB: PSU, front-to-back XN-DCPWR-2400W-BF: PSU, front-to-back | 0.93kg (2.06lb) | 73.66mm W x 40.13mm H x 185.17mm D (2.9in W x 1.58in H x 7.29in D) |
XN-4P-RKMT301 - Four-post rack mount kit (included with switch) |
2.96kg (6.53lb) | 70.1mm W x 50.04mm H x 720.6mm D (2.76in W x 1.97in H x 28.37in D) |
