Two fan module options, with front-to-back or back-to-front airflow, are available for the switch:
Airflow is front-to-back if the power supplies and fans have red tabs. Airflow is back-to-front if the power supplies and fans have blue tabs.
Fan modules are ordered separately for the base 7830-32CE-8DE switch.
For information on installing or replacing a fan module, see Replace Fan Modules.
