The following topic contains power specification information for 7830 Series switches. Refer to the Extreme 7830 Series Data Sheet for up-to-date information.
The following table includes power supply specifications for the switch.
2400W AC PSU XN-ACPWR-2400W-FB XN-ACPWR-2400W-BF |
2400WDC PSU XN-DCPWR-2400W-FB XN-DCPWR-2400W-BF | |
| Voltage Input Range | 100-120/200-240VAC | -48 to -60VDC |
| Line Frequency Range | 50Hz– 60Hz | N/A |
| Input Rating | 13.8/10A Max. for each PSU | 45A Max. for each PSU |
| PSU Input Socket | IEC320 C20 | Tyco 2204535-3 |
| PSU Output Cord | IEC320 C19 | N/A |
| Operating Conditions | 0°C–45°C operation | 0°C–45°C operation |
The following tables include power consumption and power and heat dissipation for the switch.
| 7830-32CE-8DE | VIN(Vrms) | Minimum Power Consumption (Watts)(Idle, no ports linked) | Minimum Heat Dissipation (BTU/hr) | Maximum Power Consumption (Watts) (All ports 100% traffic) | Maximum Heat Dissipation (BTU/hr) | Max AC PSU Power Output Per AC PSU (Watts) | Minimum Number of AC PSUs Required | N+1 Redundancy |
| AC PSU | 90-132V | 1225.2 | 4181.5 | 2016 | 6878.8 | 1200W | 2 | No |
| 180-264V | 1180.5 | 4028 | 1952 | 6660.5 | 2400W | 1 | Yes |
| DC PSU | 40-72V | 1197 | 4084.3 | 2015.5 | 6877.2 | 2400W | 1 | Yes |
