Your Extreme Networks AP ships with everything that you need for a basic installation. All optional brackets and accessories are sold separately.
| Quantity | Item |
| 1 | AP3020W |
| 1 | Ethernet cable. This flat cable is specifically intended to connect the in-wall Ethernet receptacle to the back ETH0 port of the access point during installation. It helps manage space effectively behind the wall plate. |
| 1 | Regulatory document |
| 1 |
ACC-BKT-WP-AP3020W mounting bracket |
| 2 | Phillips pan head wood screws |
| 2 | Phillips head plastic screw-in anchors |
