The following tables show the AP3020W power profiles. Use this information as you plan your deployment.
| Operational Mode | Radio 1 | Radio 2 | IoT | Ethernet Ports | USB | PSE |
802.3af Input: Typical 11.6 W, Max 14.5 W | ||||||
| Mode 1 2.4 GHz /5 GHz | 2.4 GHz, 16 dBm, 2x2 | 5 GHz, 16 dBm, 2x2 | Yes | Yes | No | No |
| Mode 2 5 GHz /6 GHz | 6 GHz, 16 dBm, 2x2 | 5 GHz, 16 dBm, 2x2 | Yes | Yes | No | No |
| 802.3at Input: Typical 19 W, Max 22 W (with 5 W USB) | ||||||
| Mode 1 2.4 GHz /5 GHz | 2.4 GHz, 17 dBm, 2x2 | 5 GHz, 18 dBm, 2x2 | Yes | Yes | Yes 5W | No |
| Mode 2 5 GHz /6 GHz | 6 GHz, 18 dBm, 2x2 | 5 GHz, 18 dBm, 2x2 | Yes | Yes | Yes 5W | No |
| 802.3bt Input: Typical 35 W, Max 38 W (with 5 W USB and PSE) | ||||||
| Mode 1 2.4 GHz /5 GHz | 2.4 GHz, 17 dBm, 2x2 | 5 GHz, 18 dBm, 2x2 | Yes | Yes | Yes 5W | Yes 15.4W |
| Mode 2 5 GHz /6 GHz | 6 GHz, 18 dBm, 2x2 | 5 GHz, 18 dBm, 2x2 | Yes | Yes | Yes 5W | Yes 15.4W |
