Environment and Physical Specifications
The AP3020W supports both 802.3at PoE and 802.3bt PoE.
Environment Specifications
The following list shows the environmental operating conditions for the AP3020W:
The AP3020W has the following dimensions and weight:
Enclosure
The AP3020W is constructed with a plastic top and aluminum die cast (ADC) bottom.
