Fan Modules
Two fan module options, with front-to-back or back-to-front airflow, are supported on the Extreme 8520 switch.
Fans are ordered separately for base 8520-48Y-8C and 8520-48XT-6C switches. Fans are included with other switches.
For information on installing or replacing a fan module, see Replace Fan Modules.
LEDs on the front panel of the switch provide information on the unit's operational status. See Monitor the Switch for details.
