This topic describes power supply specifications, power consumption, and heat dissipation. Refer to the Extreme 8520 Data Sheet for up-to-date information.
Power Supply Specifications includes power supply specifications for Extreme 8520 switches.
750W AC PSU XN-ACPWR-750W-F/ R |
750W DC PSU XN-DCPWR-750W-F/ R | |
| Dimensions | 3.15in W x 1.57in H x 8.11in D (8.0 cm x 4.0 cm x 20.6 cm) | 3.15in W x 1.57in H x 8.11in D (8.0 cm x 4.0 cm x 20.6 cm) |
| Weight | 1.79lb(0.81kg) | 1.85lb(0.85 kg) |
| Voltage Input Range | 100-140 VAC / 20 0 -240 VAC | -48 to -60 VDC |
| Line Frequency Range | 50 – 60 HZ | N/A |
| PSU Input Socket | IEC 320 C14 | Terminal Block |
| PSU Output Cord | IEC 320 C13 | N/A |
| Operating Conditions | 0˚– 55˚C operation | 0˚- 55˚C operation |
The following tables include power consumption information for the Extreme 8520 switches.
8520-48Y
The following tables provide AC and DC power consumption information for the 8520-48XT switches.
| Item | Test Mode | Consumption (W) | Notes | ||
| Dual Power | Single Power | ||||
| PSU1 | PSU2 | ||||
| 1 | Empty Model | 109 | 104 | 207 |
| 2 | Standby Mode | 114 | 108 | 216 |
| 3 | Typical Model | 121 | 116 | 232 |
| 4 | Stress Model | 154 | 148 | 299 |
| PSU1 | PSU12 | ||||
| 1 | Empty Model | 112 | 106 | 209 |
| 2 | Standby Mode | 118 | 111 | 223 |
| 3 | Typical Model | 126 | 119 | 239 |
| 4 | Stress Model | 158 | 152 | 302 |
| PSU1 | PSU12 | ||||
| 1 | Empty Model | 130 | 100 | 226 |
| 2 | Standby Mode | 134 | 104 | 235 |
| 3 | Typical Model | 141 | 111 | 251 |
| 4 | Stress Model | 178 | 145 | 325 |
8520-48XT
| PSU1 | PSU12 | ||||
| 1 | Empty Model | 148.5 | 136 | 275.5 |
| 2 | Standby Mode | 155.8 | 143 | 289 |
| 3 | Typical Model | 162.2 | 148 | 302.5 |
| 4 | Stress Model | 204.8 | 189 | 389.5 |
| PSU1 | PSU12 | ||||
| 1 | Empty Model | 149.8 | 138 | 250 |
| 2 | Standby Mode | 156.8 | 145 | 262 |
| 3 | Typical Model | 164 | 151 | 275 |
| 4 | Stress Model | 205 | 191 | 354 |
| PSU1 | PSU12 | ||||
| 1 | Empty Model | 161 | 125 | 280 |
| 2 | Standby Mode | 168 | 132 | 295 |
| 3 | Typical Model | 175 | 139 | 308 |
| 4 | Stress Model | 221 | 184 | 399 |
Power Supply Specifications includes power and heat dissipation information for Extreme 8520 switches.
Switch Model |
Minimum Heat Dissipation (BTU/hr) (Idle, no ports linked) | Minimum Power Consumption (Watts) (Idle, no ports linked) |
Maximum Heat Dissipation (BTU/hr) (Fans high, all ports 100% traffic) |
Maximum Power Consumption (Watts) (Fans high, all ports 100% traffic) |
| 8520-48YAC | 553BTU/ hr | 167W | 1600BTU/ hr | 469W |
| 8520-48YDC | 553BTU/ hr | 167W | 1600BTU/ hr | 469W |
| 8520-48XTAC | 642BTU/ hr | 194W | 1225BTU/ hr | 359W |
| 8520-48XTDC | 642BTU/ hr | 194W | 1225BTU/ hr | 359W |
