System Status LEDs
System status LEDs are located on the front of the switch. The following table describes the colors and the states for the LEDs.
Table 1. System Status LEDs
LEDColor/StateDescription
Power OffNo power; some power rails are dropping below specification.
GreenValid power. All monitored voltages are nominal.
System OffBoot failed.
GreenOperational.
Blinking amberBooting.
AmberFault.
Fan StatusOffNo power.
GreenFan is operational.
AmberFan failure.
PSU Status OffNo power.
GreenPower on. Main and Standby output enabled with no PSU warning or fault detected.
Blinking amberWarning. Power supply warning detected.
AmberFault. Power supply fault.
Secure OffCeC1712 is booting up or fault. CeC1712 is performing the initial load (decrypt, validate, load) of its own code, prior to authenticating images. Or the CeC1712 was unable to decrypt, validate and load its own image.
Slow blinking blue (1 Hz) CeC1712 is authenticating or updating images. CeC1712 is currently authenticating or copying golden image to primary.
Fast blinking blue (4 Hz)CeC1712 authentication failed. Neither primary nor golden image successfully validated.
Very slow blinking blue (0.25 Hz) Bypass authentication. Bypassing authentication for test or development only.
Solid blueCeC1712 authentication complete. CeC1712 successfully authenticated the BIOS Flash-0 and BMC Flash-0 images.
