Extreme 8520 switches support the following fan modules:
Use the following instructions to remove and replace a fan module in the switch.
Use the following instructions to remove a fan module.
The fan module is held in place by spring clips. As you pull, the clips disengage and the fan stops.
Use the following instructions to install a fan module.
Fan modules with a red tab provide front-to-back airflow and are labeled Air Out.
Fan modules with a blue tab provide back-to-front airflow and are labeled Air In.
Do not force the installation. If the fan assembly does not slide in easily, ensure that it is correctly oriented before continuing.Push until the fan module snaps into place. The fan automatically starts to operate.
