Power Supply Airflow Direction Requirements
All installed power supplies must blow air in the same direction and must match the airflow direction of the installed fan modules.
The operating-system software displays the airflow direction.
Warning
Warning
To prevent an electrical hazard, make sure that the AC power cord is not connected to the power supply before you install the power supply in the power supply slot.
Warning
Warning
Make sure that the AC power supply circuit is not overloaded. Use proper over-current protection, such as a circuit-breaker, to prevent over-current conditions.
