Before you attempt to install or remove an Extreme Networks switch, read the precautions in Safety Considerations for Installation.
Extreme Networks switches fit into standard 19-inch equipment racks.
A four-post rack-mounting kit is provided with the switch. A two-post kit can be ordered separately.
The installation process includes the following tasks:
| Step | Procedure | Description |
| 1 | What You Will Need for the Installation | Prepare to install the switch |
| 2 | Attach the Switch to a Rack or Cabinet Attach the Switch to a Rack or a Cabinet | Install the switch in the rack. |
| 3 | Install Expansion Modules | Install expansion modules, if the switch supports expansion modules. |
| 4 | Install Optional Components | Install optional components: optical transceivers and cables. |
| 5 | Install Internal Power Supplies | Install one or two power supplies if your switch does not come with an installed internal power supply.
Note: Be aware of whether the power supply you are installing is AC-powered or a DC-powered. The installation instructions are different depending upon what type of power is used.
| 6 | Connect the Switches to Form the Stack Ring | Connect stacking cables for a stacked configuration, if the switch supports stacking. |
| 7 | Connect Network Interface Cables | Connect network interface cables. |
| 8 | Turn on the Switch | Power up the switch. |
| 9 | Activate and Verify the Switch | Perform initial network connection and configuration. |
Section contents:
