External Interfaces contains external interfaces and weights and dimensions information for Extreme 8720 switches.
| 8720 (32 x 100 GbE) | |
| Ports |
| Power Supplies |
| Fan Tray |
| Dimensions | 17.3 in W/22.4 in D/1.7 in H (44 cm/57.0 cm/4.3cm) |
| Weight | 16.3 lb (7.4 kg) with no PSU / 19.9 lb (9.0 kg) with two PSUs |
| Performance |
| CPU/Memory |
| Packet Buffers | 32MB |
| Operating Conditions |
Operating Temperature – Front-to-back:
Operating Temperature – Back-to-front:
| Accessory | Weight | Physical Dimensions |
Fan unit, front-to-back or back-to-front | 0.14 kg (0.31 lb) | Height: 4.0 cm (1.57 in) Width: 4.0 cm (1.57 in) Length: 13.4 cm (5.28 in) |
Four-post rack mount kit (included with switch) | 2.63 kg (5.8 lb) | Height: 2.1 cm (0.83 in) Width: 4.4 cm (1.73 in) Length: 63.0 cm - 90.0 cm (24.80 in - 35.43 in) |
Two-post rack mount kit (separately orderable) | 0.45 kg (0.99 lb) | Height: 5.0 cm (1.97 in) Width: 7.0 cm (2.76 in) Length: 72.0 cm (28.4 in) |
| Description | |
| XN-RJ45-DB9-CONSOLE-CBL | RJ45 to DB9 Console cable (6ft) |
| XN-RJ45-USBA-CONSOLE-CBL | RJ45 to USBA Console cable (6ft)* |
| XN-RJ45-USBC-CONSOLE-CBL | RJ45 to USBC Console cable (6ft)* |
* The cable might require an FTDI software driver on some operating systems.
